We have an account that requires the ability to limit the number of copies per user account. Since the built-in user management application doesn't let you set a copy limit, I installed the Java SD card and loaded the User Limit software available through Ricoh. Unfortunately, it doesn't have a way to print out the number of copies used by account like the built-in software does. The customer wants to be able to print out a sheet that shows usage before resetting the counts...has anyone used the User Limit software and figured out a way to do a printout?
