Printing excel entire workbook
  • aaalexxx
    Engineer
    • Jul 2009
    • 51
    hi guys,
    i have this mpc6000 printing to excel worksheet.
    when i print colour for the entire workbook. only the 1st page come out as colour. and the rest as black and white.
    how you guys overcome this issue? possible to print out colour for all excel sheet at 1 go?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3945
    Welcome to Excel, my friend.
    Excel has a nasty little habit of only applying your setting(s) to the first worksheet; all others will print with your printer default settings.
    The easiest workaround is to set your preferences for the printer (in this case, set to color).
    Just don't forget to set it back when you're done.
    • aaalexxx
      Engineer
      • Jul 2009
      • 51
      thank u sir.
      hopefully we got drivers that overcome this excel issue.
      customer happy we less headache.
      • aaalexxx
        Engineer
        • Jul 2009
        • 51
        customer not please with the reply.
        i also shown her similar excel printing issue
        Only first worksheet prints duplexed
        O M G.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Perhaps try to print to document server, then print from there as you want
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3945
            Why not install multiple copies of the same driver, but set the preferences on one of them to duplex, then rename the driver accordingly?
            Good call on the Document Server. Although that would work, it does involve an extra step and more time.
            Please make sure the customer is aware that this is Microsoft issue, and not a printer problem. We can't fix Microsoft problems, only try to work around them.
            Perhaps other spreadsheet applications (Lotus 1-2-3, Open Office, etc..) don't have this problem.
            • zyqwiz
              • Jun 2009
              • 333
              Try holding down the shift key then selecting then clicking on all the sheet tabs at the bottom. This will select all of them. Now set the page settings and it should apply what you set to all of them.
