1 - set your computer IP on 192.168.0.100
2 - open " printer and fax" and add printer select "local printer attached" next
3 - select "a new port" " standard TCP IP " next
4- set " printer name or ip address on " 192.168.0.101 " next next
5- select your printer from list or press have disk and then select your printer driver
6 - you must change your copy machin`s IP and then you are done
