Scanrouter install
  • msaeger
    • Sep 2008
    • 333
    Scanrouter install
    Having problems getting scanrouter lite working. I can install it ok but when I try and add the IO device it fails. They bought a new pc to replace the one that had it running and the new one has xp sp3. Not sure if it will run with sp3 or not anyone gotten it working with it ?
    My guess is a port is being blocked I need 161, 80, and 3670 right ? I checked to see if they are open by doing telnet 127.0.0.1 port. Using this method 3670 is open but not 80 and 161.
    I can't find what is blocking the ports. The xp firewall is off and I can't see any other kind of firewall running.
    I tried running it on my Ricoh laptop but that appears to have 161 blocked too and it has sp3.
    Is doing telnet 127.0.0.1 port a good way to check if the port is open or is there a better way ? What they heck else could be blocking the ports is there some way to tell ?
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Hopefully this will help.
    I know that it's written for SP2, but I think that SP3 should be at least roughly the same.
    Worth a try!
