MPC 3000 faint image help
  • Belmont Turbo
    • 11
    hi i have a problem with mpc3000 intermittently goes faint in the center of the page (see pics below)
    ive replaced the pcu and developer.
    any help would be much appreciated
    thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    Methinks that'll be the laser shutter. There was a firmware update for this posted a while ago, just update the machine to the latest version. If you're going to do the firmware, do them ALL, not just the engine and controller.
    Hit it.
    • teebee1234
      • 1670
      I'm not sure that it could be the shutter unit, it's only affecting the black and just in the middle (but then I may wrong). Looks more like a dirty laser slit glass or transfer from the ITB. Check the laser glass slit first (might as well pull the laser unit out and clean all of the slits), if clean then look at the ITB unit, check the black transfer roller under the belt.
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        It is the firmware>>>>have seen this several times
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • Fearless V K
          • 620
          Had one the other day where the firmware upgrade and the SP mode shutter open/close position adjustment didn't work, ended up removing the shutter.
          Your colors are probably light in the center also, just not as noticeable as the black.
          Don't take that toner with me!
          • tcs04
            FORMER Techie
            • 1183
            It Is the shutter, but may not be firmware. Firmware was an issue on very early machines but should have been sorted.
            I had one of our guys call today from a customer with the same issue on an MP2500. The machine had up to date firmware (I think ver 1.11?), new Black PCU and dev, but still the same problem. He removed and cleaned the laser optics / polygon mirror motor and lubricated the shutter with some success but the fault did return. Ricoh suggested firmware and were suprised when the machine was up to date (!).
            He removed the shutter and the copies are now perfect! New shutter and I believe new shutter motor on order.
            • Llama God
              • Mar 2009
              • 1353
              Remove the shutter and do the firmware.
              • tcs04
                FORMER Techie
                • 1183
                V1.11:01
                B2385530J
                March 2007 production
                unlikely, unless it's an early machine
                • Llama God
                  • Mar 2009
                  • 1353
                  It's an MPc3000, there's the possibility that it's more than 3 years old now.
                  I'm not saying that I'm right, but I could be!
                  • turbojetboy
                    • Aug 2009
                    • 279
                    We just remove the shutters as soon as we see this and the problem is gone! No need to touch the shutter motor.
                    • Belmont Turbo
                      • 11
                      just to update this
                      the machine was installed around 6months ago and was new.
                      we upgraded the firmware which made no difference so we removed the shutter and the problem was solved
                      thanks for the help peeps
