he all plesa 1075
  • xuanquanghh
    • Mar 2009
    • 23
    he all plesa 1075
    AF 1075 erro SC541. reple all main and fuser but not update help me
  • Eric1968
    • 2458
    Reset with SP7-807.
    • mikadonovan
      • May 2008
      • 2931
      Originally posted by Eric1968
      Reset with SP7-807.
      I'm not sure resetting the SC/Jam counter will help with his fuser code. Enter sp mode and turn the main power off and on to clear that code, unless you still have a problem with your thermistors. On another note xuanquanghh, your English is horrible.
      NEVER ASSUME ANYTHING
      • teebee1234
        • Jul 2008
        • 1670
        Geez Mikadonovan, was that a necessary comment? I bet his English is a lot better than your Vietnamese.
        • mikadonovan
          • May 2008
          • 2931
          Boy, this post really helped him out. Not a word on how to remedy his problem, just being critical of other peoples advice and/or comments.
          • teebee1234
            • Jul 2008
            • 1670
            You're answer was correct, I was just pointing out your followup statement as being unnecessary. We are here to help on technical issues, not provide lessons on English. Especially someone who obviously is foreign and made the effort to communicate his problem to the best of his ability.
            • mikadonovan
              • May 2008
              • 2931
              Really? You have made 2 posts on this thread, and neither one is technical.
              • teebee1234
                • Jul 2008
                • 1670
                As I stated, your answer was correct, I had nothing to add to that. I was calling you out on your non "technical" comment. What purpose did that serve except to discourage him or others? We don't need to continue this conversation, I made my point. You can post your response and we'll let it lay.
                • Eric1968
                  • 2458
                  He mentioned that he replaced the whole fuser, as far as I understand it correctly, so the only thing he has to do is reset the SC.
                  • teebee1234
                    • Jul 2008
                    • 1670
                    I think the assumption is that xuanquanghh replaced the fuser but didn't reset the SC code. It wasn't made clear in his post. If he didn't then Mikadonovan's suggestion would be correct, yours would only reset the counter. We really need more info on what steps he actually took.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Actally, I was attemting to ENCOURAGE him to brush up on the 'ol English because I had trouble understanding his original post. All you were doing is citicizing me about criticizing. Ever hear of the word 'hypocrite'? (I sure hope I spelled that right ) NOW we can let it lay. We don't need to continue this conversation.
                      • Fearless V K
                        • 620
                        If you just reset the counter (SP7-807), you are still accomplishing the act of entering the SP mode. As long as you power cycle the machine afterward, the code should reset.
                        Don't take that toner with me!
                        • ivacopy
                          • Oct 2008
                          • 46
                          - Press Clear Modes
                          - On the operation panel keypad, press 107.
                          - Hold down Clear/Stop for more than 3 seconds
                          - Then turn on and off
                          Sorry for my English
                          • teebee1234
                            • Jul 2008
                            • 1670
                            I thought about that after I posted and was going to correct myself. You beat me to it
                            • Llama God
                              • Mar 2009
                              • 1353
                              Oh dear, it's getting a bit heated in here, isn't it? You ladies need to calm down!
                              Try what Ivacopy said and if that doesn't work, check the female fuser connector in the frame of the machine for paper.
                              This is assuming that the entire fuser has been swapped of course, that point was a little unclear to me.
