"Clear/Stop", "1","0","7"' and "Color Start". Maintenance Mode should display.
Up or Down key to select an item.
Going into Next Level/Returning to previous level
To go into next level of an item, select an item then press "OK"
To return to the previous level of an item, press the "Return" key
Scroll to "Engine Maintenance", there should be a sub heading for Fuser SC Reset.
These directions pertain to the MultiFunction version, not the printer version. That requires the Smart Organizing Monitor program to be loaded on a PC.
