MPC2500
  • Rajrajraja
    • Sep 2009
    • 31
    MPC2500
    Dear All,
    Please open the below links..
    One of my customer try to repair the machine (MPC2500) and somehow they manage to break the female connector(Frame side) of the drum connection.
    I am not find the part number(harness with connector) in the Parts manual.I need to order all the four harness(C Y M K).
    Please provide the same if you have.
    http://download.yousendit.com/Z01NZUN1K3hlM1IzZUE9PQ
    http://download.yousendit.com/Z01NZUN1K3gyWGQzZUE9PQ
    Regards,
    Raja.
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Raja, i dont think you can just get the connectors its the whole drive assembly in section 29. If the customer done it? get them to pay for it because its a long job and expensive one.
    good luck
    Incontinentia Buttocks
    • RICOHTEC
      • 42
      yes you have to change all drive assy
      dont forget to take the for front gear from your old drive assy .
      • serpico
        • 14
        Hello, try to insert a RJ45 connector from a network cable and pull it in place !
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          You tried to make a color PCU fit into K slot
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • TonerMunkeh
            Professional Moron
            • 3865
            Square peg, round hole. You do need to change the entire drive assembly, however there is another post on here that has the connector part numbers. Try searching for it. You will need a really bendy screwdriver to get at the screws that hold the connectors in though. It'll probably be easier just to change the whole drive.
            Hit it.
            • Rajrajraja
              • Sep 2009
              • 31
              mpc2500
              I will be ordering for a drive unit..Thank you for your reply..
              Regards,
              Raja.
