clear miter on RICOH MPC 2050 ?
  • Guest
    I want to clear the counter miter RICOH MPC 2050 is equal to 0 enough someone will help me to do.
    Thank you very much
  • abenford
    copier man
    • Aug 2009
    • 19
    You will need to buy new RAM to clear the meter. It is the only way.
    Andrew Benford | Copier Technical Support Specialist.
    • Vulkor
      • Jun 2009
      • 946
      NVRAM to be precise.
      • mikadonovan
        • May 2008
        • 2931
        Why do you want to clear the meter?
        NEVER ASSUME ANYTHING
        • Eric1968
          • 2458
          I think the total counter is stored somewhere else. It can't be that simple.
          • Jomama46
            • 2900
            All the counters including the total are stored on the NVRAM
            sigpic
            A+; Network +; PDI+
            • Vulkor
              • Jun 2009
              • 946
              Yeah found this out after having to replacing corrupt NVram on several machines. Wasn't able to back it out. it wiped out ALL digital counters. Luckily the Analog still work, so we make sure that user knows to give us the analog totals now.
              • zyqwiz
                • Jun 2009
                • 333
                Yes it is - all digital Ricohs have always been the same.
