Ricoh 1515F fax trouble recieving
  • copyaction
    • Oct 2007
    • 985
    Customer has phone service through there cable company.
    2nd Ricoh 1515F machine I brought out to them will not recieve occasionally.
    Both machines work fine in my office.
    Any settings that can be changed to make it more compatible with cable phone service?
    I should add, they hooked up a cheap Brother fax and of course it works fine!
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    in fax bit switches change:
    (SWCOM) 00 to 01100000, 01 to 00000000
    (SWG3) 03 to 01000010, 05 to 00000110, 06 to 01010110, 07 to 00011111
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • copyaction
      • Oct 2007
      • 985
      is that in SP mode?
      104 communication sw
      105 G3-1 sw
      • Venom
        • Nov 2009
        • 765
        Originally posted by copyaction
        is that in SP mode?
        105 G3-1 sw
        Yes Sir
        • copyaction
          • Oct 2007
          • 985
          Yes Sir
          many thanks, I will try it
