Add toner light on cyan although toner in machine new cartidge.
Stripped and vacced out toner pump assy still says add toner.
Removed ops panel and under tray and ran self diag on toner motor- toner clutch- primer clutch. Watched both clutches working ok.
After running for no more than 15s switched off/on.
Now message gone I take it toner has obviously reached end sensor and so
now forcing machine to accept toner cart, but is this only a temp fix.
Will it call for a new cartidge next time it runs out even though new one in!!!!
Anyone had this, I read somewhere that if you fit new dev which I had,
and the toner is low it can cause this fault. Remedy, change dev again!!!
jim.
jim.
