Jam when using B5 paper size
+ More Options
Posts
  • aaahmmm
    • Aug 2009
    • 103
    I have jam in B1 , B2 area ( registration ) of aficio 1060 when changing to B5 ( 17.5 mmx 25 mm) paper size , I check all the tray settings.
    Note: no jam when using A4 size
  • kayjaig
    • 144
    Chech ADF detection
    how about the original, did you ADF detect the same B5 size ?
    • tcs04
      FORMER Techie
      • 1183
      That would be 17.5 CM x 25 CM !
      Are you feeding SEF or LEF?
      • aaahmmm
        • Aug 2009
        • 103
        LEF feed
        the feeder detect the B5
        • tcs04
          FORMER Techie
          • 1183
          LEF feed
          (without checking the spec) I think the mchine only runs B5 SEF (?)
