mp 6000 light copy
  • jinjangu
    • Jul 2008
    • 39
    mp 6000 light copy
    I have a problem for MP6000 its given light copies everytime,I did a force toner copy is fine but after a few days again light copies. Is the anyone have ideas about this issue.Thanks in advance.
  • spaceman99
    • Jul 2009
    • 174
    replace dev B2969640 and Mag roller ( think you have to get the complete dev assy ) clean slit glass and poss change hopper.
    don't forget to go into sp mode and set charge , id and dev up.
    good luck
    • ivacopy
      • Oct 2008
      • 46
      Hi
      Check the toner hopper inside, you have to check does the toner licking or maybe don`t come out. If it`s ok you have to change the Toner Supply Rate.
      • tcs04
        FORMER Techie
        • 1183
        What is the meter reading? When was the machine last serviced? If so, was the dev set up correctly?
        Check SP2223 to see if toner is reaching the TD sensor. Are the plugs at the front of the dev unit connected?
        What is the reading from SP3103 (VSP / VSG)? If 5.0 the ID sensor may be dirty. Any Service Codes?
        Print the SMC non default settings (6) and see if anything jumps out.
        You need to check all of these before throwing parts at the machine which may not cure the problem!
        If in doubt RTFM!! (To understand the toner add sequence)
        • jinjangu
          • Jul 2008
          • 39
          i found the problem, it was the toner harden inside toner bottle
