All size ricoh/Gest. PCQ
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    Hey everybody. Basicaly all size printouts solidbut copy, adf or glass light ?
    How to udjust that. MC & DV bias is like a main adj.
    How to do only copy dens. Adj. ?
  • tekcopyer
    • Nov 2009
    • 35
    What do you mean? Print out from computer is solid and if you do photocopy is light.
    You can try to clean first all the optic section, before you do some adjustment.
    Everybody wants to go to heaven, but nobody wants to die.
    • SKTeK315
      Walter
      • Jun 2009
      • 142
      Naturally
      • tcs04
        FORMER Techie
        • 1183
        Naturally
        • SKTeK315
          Walter
          • Jun 2009
          • 142
          So. Any ideas
          • aabarnes1
            • Mar 2009
            • 620
            Well if the printouts are fine and the copies aren't then either your optics are dirty, your origionals are shite or your blind
            Grant me the serenity to accept the things I cannot change.
            • SKTeK315
              Walter
              • Jun 2009
              • 142
              Self generated prints are very good. Make a copy of it. In fact there's a difference if u copy that printout thru adf & off platen. In any case they both come out lighter. Much lighter & thinned out text
              • FrankieB
                • 12
                make sure your white balance stip is cleaned and facing the proper way
                • zyqwiz
                  • Jun 2009
                  • 333
                  Clean mirror 1 next to the lamp!
                  • SKTeK315
                    Walter
                    • Jun 2009
                    • 142
                    Thanks but all of that is done & good
                    • copyman20
                      • 207
                      what model is the machine?
