scan size on ricoh 3235-c
  • auburn business systems
    owner/technican
    • Mar 2009
    • 46
    the scan size of doc. in pdf is very large. the scan program BOTH machines used was INFAN VIEW and converted to pdf using desktop pdf. i scanned two doc's. one was 143kb and the other was 188kb. both convert to pdf files. i scanned the SAME doc's on a samsung 4725 using the SAME scam program and pdf converter. on the samsung the doc's were 4.67kb and 16.4kb. the sizes are in the same order i scanned on both. any help on this? whay are the rocoh doc's bigger and the samsung? thanks howard
  • Eric1968
    • 2458
    Maybe the Samsung uses some kind of PDF-compression. I find 4 kB and 16 Kb very small. Can you actually read documents of this size?
      owner/technican
      • Mar 2009
      • 46
      yes when i print them out on the samsung 4725 both the scanned and printed copy are the same size
      • Vulkor
        • Jun 2009
        • 942
        Maybe the Savin was changed from a Default DPI or 200 to something higher.
        • knightfall
          • Jul 2006
          • 633
          I would check like what Vulkor said, the dpi and also if it is scanning in color or black and white that changes the output size and what format you used to scan (tiff or jpg) for both equipment. you said you use desktop pdf to convert to pdf the Ricoh copier can do that for you. The format you originally scan will affect the final output file size.
          Get your facts first, and then you can distort them as much as you please.
          • stephend
            Senior Technician
            • 306
            Pretty sure it must have something to do with the way your machine is set up. I will double check the scanning resolution. I must agree with Eric1968, 4K is really small. The 144K size sound way more normal for a standard page 8.5 x 11" or A4.
            Did you try to print the 4K doc to see how it looks....pretty sure is not a good quality.
            • Vulkor
              • Jun 2009
              • 942
              Yep Screen quality vs Print Quality is a World of Difference. Learned that long ago while using a program called PRIMO PDF. It converts any document you can print to PDF. Options like Screen Print or Publication print make a big difference.
