Ricoh Aficio 2045, disable FAX delivery Report
  • m_donakov
    • 213
    How can i disable delivery report on my copier aficio 2045, becouse i send many faxes per day and i spend many paper for that delivery report, please help me how can i disable that or to get one report on 100 faxes
    Regrads
    Mile
  • Jomama46
    • 2900
    Change User Parameter switch 03 bit 0 to 0.
    As follows: User Tools>Fax>Key Operator Tools>User Parameters. Bits are numbered 7 through 0 and left to right. Change a bit by pressing its corresponding number on the ten-key pad.
    Go to Switch 03 and press the 0 key, notice that each time you press the 0 key the value will toggle to 0 or 1. The final value should be 0.
    The Auto Journal will stay in effect. You will get a report after 40 transactions.'
    sigpic
    A+; Network +; PDI+
    • m_donakov
      • 213
      Thanks that sloves my problem
      Regrads
      Mile
