Dev leak on ricoh 1060 2060 models
  • connect
    • 19
    Can any one get hold of the augers inside the dev unit. As the shaft wears the dev leaks from the bushes.
    On the older models you could order the shafts, but now there is no part number, only for the bushings.
    really dont want to order a new dev unit every time, as they aint cheap.
    thanks
  • ccchuah
    • Mar 2009
    • 153
    Only solution is to take out the paddle roller, re-fabricate the whole shaft and insert back the plastic auger with the correct position. This is what I do most of the time.
    You can't buy the paddle roller, only the whole DV tank is available.
    • connect
      • 19
      Hi, sorry for askin a stupid question,when you say re-fabricate, do you get a new shaft.
      not sure what to do with the shaft as it wears down at the ends.how exactly do you get the shaft to fit perfectly back in to the bushings.
      thanks again
      connect
      • mikadonovan
        • May 2008
        • 2931
        This is a good question.
        thanks again
        connect
        NEVER ASSUME ANYTHING
        • KYTAY
          2060 DV tank not so expensive
          Paddle roller shaft we have.
          Thank You
