Ricoh 2020: sc 120
  • White_Toner
    • Aug 2009
    • 71
    Ricoh 2020: sc 120
    Dear sirs!
    This machine makes copies without problems from ADF and exposure glass. But the interesting thing start when user try to scan. From ADF - no problem. When original is on the exposure glass, scanner starts move to the right, then to the left, through homeposition sensor, strikes of the copier body and error appears sc 120. No ideas in my minde
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Clean the sensor and flag. Clean and lube the scanner rails should fix it.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • White_Toner
      • Aug 2009
      • 71
      thanks Venom! But i couldn't understand why in copier mode it works, but as scanner doesn't work. At the same time successfuly scan from ADF. On monday i'll try do clean sensor.
      • PinevskiS
        • Jul 2009
        • 284
        Problem is scanner motor
        • White_Toner
          • Aug 2009
          • 71
          OK! Mr. PinevskiS, do you can to explane me what is the difference in the conditions for scanner motor in copier mode and csan mode? Speed or anything else? I just trying to understand:-(
          • flo
            Engineer
            • Mar 2009
            • 44
            Try to bring up oil on the way from scanner glider clean it when possible withe Airdust and bring on your Maschine from new Star (Red Button for Power on)
            Scan over ADF carrier from Scanner dont have to move Scan from Glass its go to right for lighting up your Document
