Ricoh Aficio 2090 Document Server Problem
  • elredeany2010
    • 13
    i've douments in 2090 document server and i want to copy these files to another copier 2105
    i use DeskTopBinder but when i need to copy these files there is a problem:
    device option is required to transfer copy and printer data stored
    in the document server (206-202)
    Plz Help
  • zed255
    How'd ya manage that?
    • 1024
    You require the 'File Format Converter' option to allow downloading the proprietary file format on the copier to a standard format on your PC. You would then reprint them to the document server. Short of literally printing a hard copy of everything off the old and rescanning to the doc server on the new I'm not aware of a method to move the files on a machine that does not have the file format converter option.
