MPC3500 and the like TIP
  • The man
    • 13
    Had a tray lift clutch spring snap on Tray 1 on a 3500, what a job to extract this unit from machine.
    But simply if you have this fault it's worth takin the time to remove this unit swap the clutch spring with the lower tray spring mech and when new part arrives it's alot easier to change the lower T2 tray mech.
    Cheers jim.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    No offence but why do the job twice?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Vulkor
      • Jun 2009
      • 942
      So put Tray 2 clutch one tray 1. Now tray 2 doesn't work and it is easier to Fix tray two next time. I can understand if you are doing this to send a non-seasoned tech out to replace.
      • The man
        • 13
        re tip
        Well it's just easier and faster on the return job to fit the lower clutch, no big deal!
        especially if parking is a problem!!
