Ricoh and Drum counters?
  • mrwho
    Major Asshole!
    • 4299
    Where the hell do I check the drum counters on Ricoh machines (namely the 2045 and the 2060)? I can't possibly believe that there's no such counter on these machines - but searching the service manuals I can't find it anywhere, unless I'm totally blind or it does use some odd name.
    Mascan42
    Ibid
  • Jomama46
    • 2900
    believe it!
    sigpic
    A+; Network +; PDI+
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      if you think the drum needs changing look at vsg after the drum unit has been cleaned and the id set up. It should be reading 4.0v. When the voltage starts to change its possibly indicating the drum is wearing out.
      Vsg (the ID sensor output from reading the bare drum) is set to 4.0+/- 0.2V by changing the intensity of the light from the sensor shining on the drum.
      Incontinentia Buttocks
      • nmfaxman
        • 1702
        I reset the PM counter each time I install a drum.
        • mrwho
          Major Asshole!
          • 4299
          Originally posted by Jomama46
          believe it!
          *facepalm!*
          Mascan42
          Ibid
          • Jomama46
            • 2900
            No comprende
            sigpic
            A+; Network +; PDI+
            • msaeger
              • Sep 2008
              • 333
              That one didn't have pm counters for each item built in but the pm interval for everything was 150k so you could just use the single pm counter.
              • mrwho
                Major Asshole!
                • 4299
                No comprende
                This is a facepalm. Which is my exact expression when I read your explanation. I think it's just dumb not to include a drum counter when the machine has counters for other, less important, parts. But, hell, who am I to criticize, right?
                Mascan42
                Ibid
                • mrwho
                  Major Asshole!
                  • 4299
                  Is that value global (the same for every machine), or should I start compiling a database of baseline values for each model's drum?
                  Mascan42
                  Ibid
                  • mrwho
                    Major Asshole!
                    • 4299
                    True - if you're the only one servicing the machine for some time and have everything under control. As it is, I have a couple of machines that I don't know if the drum was changed accordingly or not. But I'm going to follow bishop's advise and try to figure it out.
                    Thank you all for your replies!
                    Mascan42
                    Ibid
                    • The SIN Raven
                      And waht about the developer counter guys?
                      How can i see it, cant find it.
                      Regards:
                      The SIN Raven
                      • mrwho
                        Major Asshole!
                        • 4299
                        Yep, that developer thing is another of my problems - how to check how many copies it has?
                        To put you guys in perspective, we're talking about a 2045 machine whose PM counter reads +300k - and we have no idea whether the previous techs made the PM but just forgot to reset the counter or if the machine never had a PM done before. The main symptom that we're so far unable to solve is that the machine leaves some heavy toner blotches on the backside of the copies - even tough we replaced the developer, cleaned the transfer unit, and more stuff I can't remember right now.
                        Mascan42
                        Ibid
                        • msaeger
                          • Sep 2008
                          • 333
                          BTW the 2060 has pm counters for everything there is a pm section right before you touch SP modes. As far as toner on the back on the 2045 if I get a cq problem I just put the pm kit in pretty much everything goes bad at about the same time. Stuff on the back I would guess would have to be transfer unit or fuser.
                          Having a separate counter for everything still wouldn't help you know if the previous guy forgets to reset it.
                          • mrwho
                            Major Asshole!
                            • 4299
                            Yes, I know. But no Drum counter there.
                            That's what we're considering doing now.
                            No, I think not. But the likelyhood of someone forgetting to reset a bunch of PM counters (one for each part) I think would be far lower than forgetting a single counter.
                            But that's just me.
                            Mascan42
                            Ibid
