Ricoh 2020d scan to folder
  • Giordino
    • May 2025
    Hello all,
    I`m in need of some help.
    I`m dealing quite some time now to set-up a new folder on the network so that the users here can scan files to that folder.
    But i just don`t knwo how to do it, I also have red alot of documentation about it, including the whitepaper but alot of the things they discuss there i can`t find on our Ricoh 2020d.
    I understand that i have to set-up an new folder and make sure everybody has acces to that folder.
    The thing i don`t understand is how to set-up the Ricoh so the users can scan to that map.
    I hope you people can help.
  • Vulkor
    • Jun 2009
    • 942
    Have to use Scanrouter Lite Software. No longer Supported by Ricoh. This should be the link for it. Search these forums for Scanrouter and you'll find setup guides and downloads etc. FYI. its a Pain in the butt. Hopefully you are setting this up on XP or Server 2000/2003. Almost impossible to setup on Vista, and doubt it works on Windows 7.
    • Giordino
      Thank you !
      I will look into it, it will be on XP or 2K3.
