Need help with Ricoh 5535 problem
  • Copier_Guy
    • 543
    I have an old ricoh that makes progressively dirty copies on long runs of 20 or more. I suspect the transfer belt but wanted some input for confirmation or redirection. Please help.
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    Look at the exposure lamp for dark rings around it.If it does it is time to replace.Also look at the charge roller for toner build up.
    • Copier_Guy
      • 543
      I cleaned the charge roller but didn't check the optics. I'll do that on my next visit. Do you think the transfer belt can cause that also?
      • tuanzwickau
        I neither think to be the transfer belt.i think optics dirty,check the cleaning blade,bias ...
        • Copier_Guy
          • 543
          Much Thanks!!!
          Thanks a million for the help. I went back and checked the lamp and it had faint brown rings around it. I confirmed by cleaning the optics and the problem got a lot better although not gone. I'll order them a new lamp. Your help is much appreciated Tuanzwickau!
          Not to forget Kopyrtek!! Quack Quack Thanks alot!
          • Kopyrtek
            Copier Psychologist
            • Jan 2007
            • 407
            Glad you got it fixed.
