LD 125 optics
  • dckm
    • 79
    LD 125 optics
    I have a few Lanier LD125s, that need to be cleaned alot. There is dust on the mirrors. We had a LD122 in the same location, and same spot, and hardly ever had to clean the optics. Anybody else seeing this problem?
  • rthonpm
    • Aug 2007
    • 2859
    Was the cover over the ADF slit glass sealed down? I've seen a lot of these little machines were the doublesided tape on the end was never exposed. Also, I always install the slit glass seal from the 35/45 series machines to seal down the ADF glass. The part number is B3516523, it helps a lot.
