Ricoh 1232 Toner Reffil
  • m_donakov
    • 213
    Hi every one, does anyone know is there is posibilty to refill ricoh 1224/1232 catridges? I meen to bay toner in bottle and to refill th catridge i have? Is there is any compatible toner ?
    Regrads
    Mile
  • Vulkor
    • Jun 2009
    • 942
    Never seen these Refilled. Suppose it may be possible. Voiding Warranty and causing serious problems with the DV units. These are the worst machines ever and you will just be adding Gasoline to a Fire.
    • Jomama46
      • 2900
      Besides that, there is a chip in the cart that counts the pixels and indicates when to replace.
      sigpic
      A+; Network +; PDI+
      • Llama God
        • Mar 2009
        • 1353
        You can probably buy compatibles from Katun or Parsia, if you dare
        • nmfaxman
          • 1702
          NEVER use non OEM in a color Ricoh. You are just asking for problems, especially the 1200 series.
          • zyqwiz
            • Jun 2009
            • 333
            get a pack of crayola crayons and a fine cheese grater - that'll get you started
            • m_donakov
              • 213
              Chips can be reset but i cant find toner is there any toner from others compatible with ricoh 1232c
              • Eric1968
                • 2458
                Do yourself a favor and DON'T use refills on these machines. Like Vulkor said above : it's like you're throwing gasoline on a fire!
                • m_donakov
                  • 213
                  But i have one old machine it isn print well i want to throw it, before that i want to try to refill one catridge if there is any toner in botle i can bay
                  • zyqwiz
                    • Jun 2009
                    • 333
                    Originally posted by m_donakov
                    i want to throw it
                    If that is true, why does it need to work?
                    • teebee1234
                      • Jul 2008
                      • 1670
                      If you were able to get refill toner it would most likely be some large commercial size quantity. No savings in that.
