2 lines when using ADF only in the aficio 1060
  • aaahmmm
    • Aug 2009
    • 103
    Dear all
    I have 2 lines at the bottom of the page .just when I use the ADF (at the front side only) . I clean all the optics but the problem still apparel
    Pleas find attached image
  • aabarnes1
    • Mar 2009
    • 620
    If this happens only when using adf then it has to be a very small mark or dirty spot on the scan glass. If you do double sided thru adf (2-2) what is the result? Is the mark on 1 side or both? Sometimes even the smallest hair or residue of tippex can cause lines like these.
    Grant me the serenity to accept the things I cannot change.
    • aaahmmm
      • Aug 2009
      • 103
      the line also apear adf (2-2) but in the front side
      sometimes its 1 line and sometimes 2
      this happens only when i using adf
      • Llama God
        • Mar 2009
        • 1353
        Definitely optics, sorry.
        You can tell because a) it only happens from the ADF and b) the edges are erased.
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Be sure to clean CIS in ADF and mylar guide. as well as optics.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • tjvincent
            • 280
            Why don't you try flipping your slit glass end for end and see if lines go to the other end of the page.
            • Llama God
              • Mar 2009
              • 1353
              I like that!
              • zyqwiz
                • Jun 2009
                • 333
                I've had dust get inside the DF CIS for the back side even though they are supposed to be sealed.
                Managed to blast it out with a can of compressed air.
                • rednecktech
                  • 54
                  I agree, definitely something on the optics, slit glass to be exact. Try putting the copy with the lines on the glass as if you were going to make a regular copy off of the glass. The lines should line up with whatever is on the slit glass. Shine a flashlight, it may be something black that you can't see well. Good luck!
                  • Fearless V K
                    • 620
                    I've seen scratches in the slit glass cause that.
                    Don't take that toner with me!
