c2800
  • T911
    • Jun 2007
    • 628
    c2800
    got an existing customer that just picked this one up and wants us to set it up for them. it's brand new out of the box. unfortunatly i do not have the service and parts for this one but i will assume the developers need to be calibrated along with all the drums in sp mode. is there anything else i should be aware of for this set up. does the fuser need to be adjusted, is the scanner locked?? manuals would be much appreciated. thanks t
  • Gary Bowen
    Bowdog
    • Mar 2008
    • 250
    There is no setup required for the PCU's or Dev's. The machine will automatically setup the Dev when you turn it on; make sure to remove the Tape Seal from the 4 Dev Units. SP5045-001 (Counting Method) is set to Developments from the factory, and SP5104-001(11X17) is set for a SINGLE click instead of 2. If you provide an email I will send you the manuals.
    • T911
      • Jun 2007
      • 628
      hi Gary,
      thanks for the info. the manuals would be fantastic. my e-mail is
      mitatips@comcast.net
      thanks so much. T
