Aficio 1075 finisher not recognised
  • zoran.riko
    • 54
    Conector, IO board and main board are changed and still the finisher is not recognised (work on other machines) . Could be a power supply board?
  • zoran.riko
    • 54
    Solved! 24V line from PWB board, fuse blowed!
    • Vulkor
      • Jun 2009
      • 946
      Quick solve, Thanks for updating with completion.
      • zyqwiz
        • Jun 2009
        • 333
        We had a dead AP3800c - changed the power supply and it turned out to be the actual on/off switch not working!
        • imaginemoko
          unTrusted Tech
          • Jan 2008
          • 289
          @zoran.riko
          are you reffering the Fuse 108?
          @zyqwiz
          i have visit a Nausatec 513d who happenly change the power supply by my teamate yesterday but still deadset... same thing i found that the main swith is burn out.....
          fix the customer first then fix the machine... its simple and makes life more easy.
