Ricoh MP6500 GBC Stream Punch III; Hole alignment Off.
  • wilfirds
    MP6500 Ricoh copier with a GBC-Stream Punch III hole allignment OFF. I need to adjust this hole punch distance between holes. Is this done via control panel or physically inside the hole punch? Where are the adjustment screw?
    Thank You.
  • zed255
    How'd ya manage that?
    • 1024
    The distance between the holes is fix by the die design. Are you perhaps referring to centring the holes on the page or are they too close / far from the edge of the page?
    In the case of centring, there is an adjuster on the back of the die rails that controls how far in the die can go.
    In the case of how near the edge you have to adjust the back stop assembly.
    GBC StreamPunch, ugh, what a nightmare.
