How to reset Password on web image monitor? machine MPc2550
  • Gesttech
    • Oct 2009
    • 123
    Hi
    Please can somebody tell me how to reset user name & password for web image monitor on MPc2550.
    My client forget user name, password and change default user name (admin). can not configure on web image monitor. what to do?
    Thanks.........................
  • Vulkor
    • Jun 2009
    • 946
    PM'd you with info.
    • [Horus
      • Nov 2009
      • 17
      Reset admin password in web image monitor.
      Hi,
      I have the same problem with one MPC2000. The client forget the admin password.
      Can you send me a PM with telling me how can i reset the password.
      Thank's.
      • zed255
        How'd ya manage that?
        • 1024
        Try logging in using the 'supervisor' account, there should be no password by default. The only function of the supervisor account is to manage the administrator accounts. You will have access to no other settings.
        • [Horus
          • Nov 2009
          • 17
          iap,
          The user: supervisor work's.
          thank's.
          • M0scb
            • Oct 2012
            • 32
            Re: How to reset Password on web image monitor? machine MPc2550
            FYI if the supervisor password has also been changed along with the admin passwords, the only way to gain access is to replace the NVRAM. If the customer has done this, and forgotten it you could make this a chargeable call.
            • zed255
              • 1024
              That is not strictly true, there are other work arounds that do not involve the replacement of the NVRAM.
              • gasino
                • Mar 2013
                • 8
                try running the sp
                5801-011
                5801-010
                • vargue
                  • Oct 2011
                  • 404
                  hi every body i have problem with mp4000 .machine required user name and password i tried all thing administrator and supervisor .no avail. i need help . if some one has clue .far away from replace nvram .thanks
                  • sandmanmac
                    • 3981
                    Originally posted by gasino
                    try running the sp
                    5801-011
                    5801-010
                    Nope...that won't help
                    • gasino
                      • Mar 2013
                      • 8
                      I think it is worth trying because the service manual says:
                      5801-011 (memory clean NCS) - Initializes the system default and interface settings (IP address also), SmartDeviceMonitor for Admin, WebStatusMonitor settings, and the TELNET settings.
                      Another solution would be to make a upload a NVRAM a good equipment for a sd card, then do a download of data from the sd card to NVRAM bad equipment.
                      • vargue
                        • Oct 2011
                        • 404
                        thanks guise i figure out .
                        • Tahir Abbas
                          • May 2020
                          • 10
                          [QUOTE=gasino;350401]I think it is worth trying because the service manual says:
                          [/QUOTE
                          No it didn't work
                          • tsbservice
                            Field tech
                            • 8020
                            No it didn't work
                            Dude this so old thread that probably nobody posted here but zed255 and sandmanmac are still active.
                            Start your own thread and better description of what have you done.
                            Last edited by tsbservice; 09-19-2020, 08:34 PM. Reason: Correction of active members
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              [QUOTE=Tahir Abbas;1569181]
                              [/QUOTE
                              No it didn't work
                              The only way to reset the admin password is though supervisor or factory service mode old thread
                              Regards Mark
