MP - 4000B False showing Used toner bottle full
  • sabah_karim
    • Sep 2009
    • 67
    Dear All
    One of my MP-4000B falsely showing used toner bottle full.
    From transfer unit throw all used toner but still the massage
    same appearing used toner bottle full.
    Looking for all yours tips.
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Scraped off toner and paper dust falls into the toner collection tank [B] in the transfer belt unit. This toner
    is not recycled. When the toner overflow sensor [C] detects toner overflow, the toner overflow indicator
    lights. Up to 999 copies can be made before the toner overflow condition shuts down the machine. P591 service manual
    clean the toner flow sensor on the transfere unit - didn't see an sp mode to reset it so clean it according to the manual if that doesnt work check it in input mode.
    errr yes you can turn it off. With sp 2960 and set to 0 for no or 1 to yes but if its set to 0 remember to clean it out periodically.
    Incontinentia Buttocks
    • TonerMunkeh
      Professional Moron
      • 3865
      Just switch the bugger off. These shitboxes don't make it that far between service calls where it will get a chance to fill it's waste tank.
      Hit it.
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        Bulletin on this
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • Gary Bowen
          Bowdog
          • Mar 2008
          • 250
          There was also a second Technical Bulletin for this problem that involves parts replacement.
