Hello, I have always replaced the PCU as an assy on these machines , I am tring to lower my cost by rebuilding a few and have found conflicting info on the dev type ie: 18, 28 and 22 "i dont even think there is a type 22" anybody know for shure? Thanks....Ant
Ricoh 2022 / 2027 Developer Type for PCU Rebuild
Use the Type 28, it's the right amount of developer.Last edited by Screw Turner; 02-22-2010, 07:53 PM.Comment
Don't expect them to last much above 40-70k after the rebuild. They do chew up their auger drive gears quite quickly after being rebuilt.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it.Comment
Ohh my God.......technicians are the only ones that don't trust technical stuff !Comment
Developer type
Hi
I rebuild these all the time type 18 or 19 will work I would replace the gears, clean the charge roller
and apply a thin coat of ne finish polish this will help stop the thin lines from coming back. if you rebuild them more then 2 times you will start having problem with them.Comment
Ricoh tried rebuilding them for a while and they didn't last for anything. The newer machines are the same design with an extra screw so you can take it apart easier, but as already noted they don't last either. We used to be able to get the type1027 new for less than the parts to rebuild one, but that was too easy and Ricoh put a stop to it.73 DE W5SSJComment
