No copy only lines on A 3030
  • bostjanma
    • May 2025
    Hi,
    I have problem newer seen! When the copier A3030 is still cold they work normaly but if you make aprox. more then 100 shets they start copy only lines with very low background of copy. In attachemend is sample. I checked all conectivities, bords and laser but they looks good. Any idea from your side?
    0525_001..pdf
  • TonerMunkeh
    Professional Moron
    • 3865
    That's a pretty pattern. That's got to be board, HDD or memory. Try unplugging the HDD first, then do the same copy job. If that doesn't work, go for memory, etc etc. You'll soon track it down.
    Hit it.
    • Moza
      • 232
      Try new laser unit have had this before mainly due to people not cleaning filters. The machine gets to hot inside causing laser unit to warp
      • Jomama46
        • 2900
        My moneys on a hard drive
        sigpic
        A+; Network +; PDI+
        • Voltage
          • Jul 2008
          • 282
          Mines on memory
          • copytrust
            • Feb 2010
            • 115
            did you change the drum???? it looks like drum problem
            • Ricohslave
              • 27
              +1 on laser problem
              • lvsb
                • Aug 2008
                • 70
                Definitely memory
                • paperclipsandbubblegum
                  • Sep 2009
                  • 29
                  Yes to memory...but try a scanner memory clear first. this was a common problem on the 1027's
                  • Joelzkie
                    • 37
                    Sir,
                    How about the cleaning blade? Have you try to replace or clean them?
                    • bostjanma
                      Definitely is nothing around the drum! I changed the drum few times. First I start with memory - changed RAM. We will see if it goes beter?! The machine is only copier without printer and HDD.
                      • Joelzkie
                        • 37
                        what i meant is the cleaning blade. have you replaced them? continuous printing or copying may result in poor cleaning especialy when your cleaning blade is deteriorated and you are copying continuously. and the machine is hot.
