Gestetner aficio 2212 (Ricoh 2022) add toner problem
  • Krag
    Hello.
    I need an advice for B089/B093/B097 machine.
    I rebuild the PCU today with new parts and new dev (OEM type 28, 345grams). After developer initialization everything works fine but after 10 pages ADD TONER error apears and the print is fading. I make a couple of Forced Toner Suply but no results after another 50 pages. The print is more lighter and ADD Toner error keep to appear. I check and clean the toner hoper and everything is ok, the toner is spining normaly and toner flow.
    I make the PCU to pieces again, cleaning and verify all again (not change the new dev) and after that put back in the machine. When I put it back, the toner is added corectly to the PCU in the initialization process and the print was black. After 10 pages the printing was lighter and lighter again but the ADD TONER error appears after 50 pages when the print was almost white. I have no clue about what is happening here. I make even 2: 2802 Developer Mixing. I check the TD senzor Vts and his value was 3,46. No SC error until now.
    Any sugestion?
    Thank you.
  • pocket aces
    Ricoh Technician
    • Nov 2008
    • 72
    that pcu is a supply item thru ricoh its not meant to be rebuilt
    • ucinn
      • Jun 2009
      • 383
      Originally posted by Krag
      Hello.
      Any sugestion?
      Thank you.
      Could be the toner hopper. The flaps that send the toner down to the developer assy sometimes break loose. Replace the toner hopper. Easiest and least costly thing to try first. That's usually what it is.
      • Fearless V K
        • 620
        make sure mag roller and toner auger drive gears in the PCU are not stripped.
        Don't take that toner with me!
        • gernah
          • Jun 2009
          • 57
          Hello.
          Any sugestion?
          Thank you.
          Sir im sure your problem regarding with the all gear in the development unit,Did you change the gears?
          • sakura
            • 132
            Wow what a wasting of time and nerves
            My answer is a TONER HOPPER unit (*aka toner supply unit) ($20 thing cost you a day of work and $$$$ to your employer). My advice to you for the future - DO NOT try to make things more complicated than they actually are
            • zyqwiz
              • Jun 2009
              • 333
              it won't be the hopper - he only changed the PCU
              • ucinn
                • Jun 2009
                • 383
                Lordy knows I've never had another part go bad at the same time as working on another....you are right, can't possibly be the toner hopper. Of course when I do drum and developer, I remove the toner hopper and vaccuum the thing out and the rest of the machine.... those things could go bad if you just look at them wrong. It is what I would try first before gettting into expensive and time consuming stuff. I do the obvious stuff first, maybe I'm in the minority here.
                • Krag
                  The problem was solved this morning. It was 20.30 clock and I was not thinking very well. One of the tooth from mag roller was half broken. This gear work with lower gear from developer box and mix the developer. This mag roller gear not working at all. Yesterday I change only the gears from developer box. I hurry a litlle and from this cause I work a couple of hours for free .
                  About toner hopper, it was one of my first checks. I check even the 4 wings.
                  Thank you for replys.
                  • Fearless V K
                    • 620
                    My advice to you in the future would be to lose the attitude, and listen to the words of experience, and actually read the problem post. The guy said he cleaned the hopper and everything was OK and toner was flowing.
                    • aabarnes1
                      • Mar 2009
                      • 620
                      I agree Fearless,totally. perhaps a type1027 pcu would have solved his problem initially.
                      Grant me the serenity to accept the things I cannot change.
                      • copyaction
                        • Oct 2007
                        • 985
                        I just want to know where to get the toner hopper for $20, I'm paying $90 at PR
                        • Fearless V K
                          • 620
                          We get the dealer price from Ricoh and it is still 45 or 50 bucks.
