1515 twain scanning
  • GhostInTheMachine
    • Feb 2010
    • 88
    1515 twain scanning
    I have 2 of these on the same network. The first one is working. When I tried to set up the second one, the twain driver always sees the first one automatically. There is no way to select a different scanner. Has anyone else run into this problem? I hope this makes sense.
  • Sashko
    • Oct 2009
    • 110
    In main window of TWAIN driver settings you must push the button "Details" and then "Select".
    In the next window you are able to select one from all available network scanners.
    • barratec
      • Jun 2008
      • 162
      If you want that a pc always points to a particular 1515 scanner you have to write the IP address of the machine in SCNHOSTS file:
      you can find it in this path C:\WINDOWS\twain_32\Ricoh_V3\NeoStC2E\ScanCTRL
      open the file with NOTEPAD and write th IP address in the first empty line, than save and close. See the attached file.
