Re: MPC 6500 7500 Blowing toner
One item that has helped me quite a bit (as in I'm only seeing the machines every 6-8 weeks instead of almost on a weekly basis) is a drum ground plate that mounts onto the front drum stay plate. These can be purchased from a company called NA Trading go to natrading.com or call 952-888-7654 and ask for Burke Balay. Hope this helps I have also tried taking the springs off of he lube bar on one machine and don't have enough data yet as they don't run it to hard but haven't seen the problem in over a month or so. Good luck
