How to use the tray parameters in a Ricoh MP(c)4000 by the webinterface
  • 107107
    • May 2025
    How can i use the tray parameters in a Ricoh MP(c)4000 by the webinterface in the printer settings
    Has somewone a list of those parameters for a copier with 4 trays and a bypass en a LCT
  • aabarnes1
    • Mar 2009
    • 620
    Tray parameters are in user tools and cannot be changed via web interfce. You have to do this at the machine.
    Grant me the serenity to accept the things I cannot change.
    • zyqwiz
      • Jun 2009
      • 333
      Not true - log in as administrator then go to configuration, then device settings (paper)
      • 107107
        In the webinterface(choose in the printer section) you have for for each tray 3 fields to specefy the tray parameters . Question is how dus it work and who can give me a list or a tool for using the parameters.
        • zed255
          How'd ya manage that?
          • 1024
          Those are for remapping paper tray calls. Let's say a client was using an HP printer and a legacy application where the paper is typically drawn from the paper drawer (source #1), and upgrades to a Ricoh. The customer soon realizes that the legacy application always causes the Ricoh to prompt for paper in the bypass and wants to know what to do about it. The tray parameters will let you 'reassign' a specific tray call to a new tray. So, you'd reassign the tray #1 call to tray#2 (which is actually the first drawer in the system) to correct the issue. Be aware that this will remap all tray calls and so may affect Windows printing. Hope that helps some.
          • unisys12
            • 490
            You should be able to find a list a Ricoh PCL commands on TSC. I have used this quite successfully a number of times.
            sigpic
            The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
            • 107107
              Hey can you mail me the complete link of this website. Tanks for so far
              • unisys12
                • 490
                TSC is the Ricoh technical portal. If you do not have access to some sort of Ricoh web based tech support, maybe someone in your shop does. Or you could call tech support and they can help you with what code to put were. Since the document in question is a copyrighted Ricoh document, I cannot post it here.
                sigpic
