Can Not Printing Custom Size Paper Gestetner MPC 2500 from bypass tray
  • Yetno.0103
    • 63
    I Have problem when print custom paper size (490 mm x 300 mm) from bypass tray on gestetner mpc 2500, when i click print on computer, the data in led was on and flash for 3 or 5 times but my document didnt printing. I tried print A3 and A4 from bypass and every thing running well. So any one here have promblem like that, give me your solutions....
    I Attach my document here
    map..pdf
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Do you need to enter a User Code to do color printing?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Yetno.0103
      • 63
      No I dont, My operating system is windows 7, i downloaded new driver from ricoh site. I can print pdf file now, but i cant print corel file. any suggestion
      • MTMEX
        • Oct 2009
        • 7
        in service mode in feed section turn on bypass auto detect
        • ccchuah
          • Mar 2009
          • 159
          can't print custom size
          From the printer properties, select the by-pass tray, enter the specify size, try to print again.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            It looks like your custom page size is larger than what the machine will support. According to the Product Support Guide, the largest supported size is 12 x 18 in, or 305 x 457 mm.
            My hunch is that you're using the auto scaling feature of Acrobat (or Reader), so the page prints.
            Corel (I'm assuming CorelDraw) is a different animal completely, and is probably one of the most difficult applications to print from reliably. You may be forced to convert the document to a PDF to print it; I think that CorelDraw can do this natively.
            • Yetno.0103
              • 63
              Maksimum Area When using Printer fuction 305 mm x 600 mm, but when you are using copier function just 305 x 457 mm can be print. I want to print 300x490 mm from my computer. I can print it when i convert my corel file to pdf file (publish pdf) but when i want to print from corel application it cant.
              • Yetno.0103
                • 63
                Yup I know that.
                • Yetno.0103
                  • 63
                  i ill try your idea, thanks
