Data in Light blinking not non-stop on MPC2500
  • lzenl
    • Jun 2025
    I got a problem here. Using PXLmono driver, together with ghostscript and fotorip to do printing on the MAC OS 10.6 on the the MPC 2500
    The copier doesn't comes with Postscript 3. The thing is that, user might had install a PS driver in the printer & faxes on the MAC and sent over a print job.
    *The Printer with PS driver has been deleted on the mac so no print queue can be seen
    The data in now starts blinking non stop and it cannot be remove even if u on and off the machine, or job reset it on the machine. It just blink for days. This disrupted th printing, now no one can print on the machine.
    Any advice how to rectify this issue?
    Help
  • Vulkor
    • Jun 2009
    • 946
    I know there is an SP for formating JUST JOBS, Got the Service Manual? I think its 5801-4 Could be wrong though. I had this happen on an 8090, wouldn't clear even after a format. Ended up replacing the Hard Drive.
    • spaceman99
      • Jul 2009
      • 174
      HI:
      Have you tried powering up the machine with out the network cable in.? does it still flash. If not then the job is in the network Q.
      You may need to stop - start Print services.
      With out the network cable in power the machine up with the HDD discornected. You should get a completely different error. This will tell you if the machine is fine. You can also format the HDD using a USB caddy.
      Another way is to Format the HDD in Sp mode Sp5XXX? from the bottom up. It does not always work when you try Format all.
      Good luck
