If you look in the Detailed Description area of the service, that address the controller, you will find that sometimes it will tell you. Pretty vagu though. Most of the time it's like, "... at least a 80gig SATA hard drive must be used."
General rule for me though... I won't put a smaller drive in.
sigpic The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
The idea is to put a 32Gb SSD instead of a standard HD. It's more expensive, yes, but much less prone to malfunctions - namely for those customers whose machines already go on their 3rd or 4th HD so far.
' "But the salesman said . . ." The salesman's an asshole!' Mascan42
'You will always find some Eskimo ready to instruct the Congolese on how to cope with heat waves.' Ibid
Hmm wonder if those handle the same way. I know there are TWO TYPES of Solid State Drives. One that formats with windows normally, and one that requires a special utility. Think you want the Intel Drive if you are gonna test this on a copier.
Also keep in mind that some SSD's are slower than standard spin drives. From what I've read, there are utilies that you can load on XP NetBooks (which are starting to pop up alot) that increase the performance on these drives. But I have also read where others have seen great performance increases by moving over to SSD's. But the newer one's are really expensive. Just be sure to compare read and write speeds.
We had an older model that one of the techs accidentlly grabbed an older 20 gig drive and put it in a new MFP that uses a 80g and it wouldn't work.
$40 for a drive from TigerDirect doesn't sound that bad to me, compared to $195 for a PATA 16g SSD and $80 for a 30g SATAII SDD after a $40 rebate.
Reason: Added drive specs and other incompentace
That 3000MB/s is what's called a burst speed - its the transfer speed from the internal cache memory through the interface. The sustained read speed is going to be MUCH lower - the SSD will have it beat. Its write speed on the solid state drives you have to watch - read / write performance on a mechanical drive is fairly symetrical, but SSD's have to read, erase, then rewrite entire sections of memory, so the performance is good if your replacing the entire block, but sux if you update a few bytes in a bunch of different blocks. That's where the better drives with better cache controllers come into play.
You also need to remember that SSD's are only good for so many write cycles before they give up - spindle drives don't care. In a laptop its not a big factor - once the OS and programs are loaded there is very little written to the drive (except the paging file but there's ways around that) Not so on a copier, every page scaned writes to the drive
