SR 5000 finsher slows down too much when stapling on the PR01357
  • rickyd
    • Aug 2025
    when doing a stapling job on the PR01357 the machine slows a job down by 30 min to 45 mins per job
  • TonerMunkeh
    Professional Moron
    • 3865
    Firmware bug? Might be the finisher needs a firmware update to run at Katana speed.
    Hit it.
    • rickyd
      I have 2 Pro1107 and 2 Pro 1357 with Sr5000 and I have the same problem when doing a stapling job
      on these machines.
      they are really slowing down and there is no differnce in speed when stapling the same job on the 1100 and the 1357
      I have checked some of these machine have the latest firmware and there is no difference. they are slowing down alot
      • Rorschach
        • Nov 2008
        • 64
        I'd lean towards a firmware update. I did see that if you're using an interposer, there is a system firmware update to address a loss of print speed.
        Also, are you punching these staple jobs? IIRC, the SR5000/PU5000 combination cannot run at 135ppm while punching, and will slow down to ~110ppm... This doesn't explain such a huge jump in job time, though...
        Today's subliminal quote is:
