Lanier 6720
  • ucinn
    • Jun 2009
    • 383
    Lanier 6720
    Do any of you old Lanier techs remember what a U4 error code is on one of these? Had one come in, don't have the error codes anymore.
  • teebee1234
    • Jul 2008
    • 1670
    I'm pretty sure it's waste toner full. If you don't have a replacement and just empty it, you will probably need to wash it out to clean the part that sits in the photo interrupter. The bottle is translucent and toner will stick to the walls causing it to continue reading "U4". "U" codes are related to "user" issues and I believe this is a Panasonic box.
    • ucinn
      • Jun 2009
      • 383
      Originally posted by teebee1234
      I'm pretty sure it's waste toner full. If you don't have a replacement and just empty it, you will probably need to wash it out to clean the part that sits in the photo interrupter. The bottle is translucent and toner will stick to the walls causing it to continue reading "U4". "U" codes related to "user" issues and I believe this is a Panasonic box.
      Yes, I couldn't remember which was which.. there was a u4 and u1.. 1 was used toner, the other was front door open. Thanks.,
      • teebee1234
        • Jul 2008
        • 1670
        That sounds more like it, I was a little fuzzy on which was what. How is it you can still service it? Are parts still available?
        • ucinn
          • Jun 2009
          • 383
          No parts are available that I know of. It's a chargeable call, so I was going to tell them they need to find a used toner bottle somewhere or how to fix it. I'm sure they don't want to pay to have me come out and tell them I can't fix it.
          • teebee1234
            • Jul 2008
            • 1670
            Looks like Precision Roller has some parts available. You can direct them there.
            • zyqwiz
              • Jun 2009
              • 333
              Luckily our system still has the old errors on for the sake of service history as I've not seen one for about 10 years!
              U0 COPY/KEY COUNT METER PROBLEM
              U1 FRONT COVER PROBLEM
              U4 PAPER JAM IN SORTER
              U5 DUPLEX DRAWER NOT SHUT
              U6 SIDE DOOR NOT SHUT
              U10 DOCUMENT FEED COVER IS OPEN
              U11 SORTER/STAPLER PROBLEM
              U12 STAPLER EMPTY
              U13 TONER EMPTY
              U14 WASTE TONER BOTTLE FULL
              U15 BYPASS TRAY PROBLEM
              • ucinn
                • Jun 2009
                • 383
                U12 STAPLER EMPTY
                U13 TONER EMPTY
                I'm glad I wasn't able to get ahold of him yet... looks like the sorters the problem then. Thanks
