AF1224 Error Code FC571
  • ricardobres
    • 147
    My customer bought this machine, and on the transport, oil was poured into the machine. The machine was working well, what happened? Another doubt, I do not know this machine, is it a good machine? I work with canon and xerox machines, color and PB.
  • Vulkor
    • Jun 2009
    • 942
    SC571
    Fusing oil overflow
    • The oil overflow sensor detects oil.
    • When the machine covers are
    closed, the oil supply unit is not
    detected.
    closed, the fusing unit is not
    detected.
    • Defective oil end sensor
    • Defective oil overflow sensor
    • Defective sensor cable
    • Oil supply unit not installed
    FYI, this is NOT a Good Machine, just search the forums. And now you possibly have OIL All in the Fusing unit or worse the transfer Belt.
    • ricardobres
      • 147
      Thanks Vulkor
      • Vulkor
        • Jun 2009
        • 942
        NP, best of luck Richard, pull the fusing unit out, and PCU unit and check for oil spills.
        • pLatik
          • 169
          • ricardobres
            • 147
            ok guys, the machine is in another city, and I still have not been there.
