MPC3300 - Scan to multiple PDF files even though "Multipage" is selected
  • mrwho
    Major Asshole!
    • 4299
    Talked today to a customer via telephone who complained that his machine would, since some time ago, scan to multiple PDF files (one per page) even though he selected "Multipage" from the panel.
    I searched my documentations and didn't find anything related to this - and honestly, I never had one of these happen before.
    I need to either give him an answer via telephone or go there myself - But I'd like to know if any of you ever had one of these or if this is a first.
    Cheers!
    Mascan42
    Ibid
  • teebee1234
    • Jul 2008
    • 1670
    I've neverheard of this issue, it's hard to say if they're making the right selection without actually being there. Do they experience it with scan to email and scan to folder? Maybe needs a firmware refresh.
    I realize you're familiar with how to make the settings but I'll post them for anyone else who may not be familiar. Here is the scanner guide, go to page 166. They may have the default setting set to single page, if they select multipage, once the job is finished it will revert back to single page.
    scanner op guide
    In order to make multi page the default,
    Registering the Default Values of the Scanner
    1. Make the necessary scan settings on the initial screen.
    2. Press the [Program] key.
    3. Press [Program as Defaults].
    4. Press [Program].
    A confirmation screen appears.
    5. Press [Yes].
    The current settings are registered as defaults, and then the initial screen reappears.
    Let us know what the fix is, thanks.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Make sure that "Divide & Send E-mail" isn't set for "Yes (per Page)".
      Check out the attached screenshot.
      • mrwho
        Major Asshole!
        • 4299
        Thanks to you both - I'll contact the customer today and see what I can find out.
        Cheers!
        Mascan42
        Ibid
        • knightfall
          • Jul 2006
          • 633
          I haven't had this problem before but I would check history and re-flash firmware, this sounds like an application/memory failure.
          Good luck
          Get your facts first, and then you can distort them as much as you please.
          • mrwho
            Major Asshole!
            • 4299
            Turns out a colleague had already called the customer and solved it - customer wasn't pressing "OK" or something like that.
            Thanks everyone. Cheers!
            Mascan42
            Ibid
            • unisys12
              • 490
              I was going to suggest this, but... It's just so obvious, I didn't. But, hind sight's 20/20, I would have asked the client the samething. so...
              sigpic
              The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
              • msaeger
                • Sep 2008
                • 333
                That's a problem when attempting phone fixes you don't want to piss off the person by insulting them and asking something too obvious. I usually do though sometimes they get mad but usually they haven't tried it.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Slightly off topic, but:
                  I have a customer that works for an educational facility in the Midlands. She has a horrible nickname which she herself likes and quotes on a regular basis. ANY attempt to telephone fix a call with her will automatically result is your head being torn off and shoved up your arse. I love customers like that. Honest.
                  Hit it.
