Ricoh Aficio 1075
  • tcypy1961
    • 773
    Ricoh Aficio 1075
    The document feeder on this copier was having problems so I swapped it out with another feeder. However the feeder I put on will work at times but more times than not when you copy from the feeder, the feeder just keeps running constantly until an SC955 error code comes up. I was wondering if the document feeder is the cause of this, and what is causing the problem in the feeder? Any help appreciated, thank you.
  • Jomama46
    • 2900
    Sounds like an IPU or Hard Drive. Inspect the cables on the IPU first.
    sigpic
    A+; Network +; PDI+
    • tcypy1961
      • 773
      I made a mistake in my description of the problem the RADF that I tried does pull the original in and the copier pulls the paper from the cassette yet the copier not the feeder continues to run for a about a minute before the SC 955 error code comes on. I don't know if this changes your info solution or not.
      Thanks!!!
      • Matoku
        • 173
        tcypy,
        do you solved your problem with this thread?
