Mpc 6501 Paper type
  • dlums
    • 14
    Mpc 6501 Paper type
    Hi All, is the Mpc 6501 capable of running 170gsm glossy paper through the trays, I have a customer that is having continuous jamming issues with this paper type even on thick paper 2 setting. Cheers
  • Rorschach
    • Nov 2008
    • 64
    Per the specs given in the FSD, you can run the following paper weights:
    Trays 1 and 2
    52.3 – 216 g/m2
    14 Bond – 80 lb Cover
    Tray 3
    52.3 – 256 g/m2
    14 Bond – 90 lb Cover
    Bypass
    52.3 – 300 g/m2
    14 lb Bond– 110 lb Cover
    Duplex mode
    60 – 216 g/m2
    17 lb Bond – 90 lb Index
    Bear in mind, these specs are for bond, not glossy. Also, despite these specs, I'd give serious consideration to using the bypass, and setting it to thick 3.
    Today's subliminal quote is:
    • dlums
      • 14
      Thanks very much for the info, Unfortunately I do not have a bypass on the machine as it has an A3 Lct attached, if you set it to thick 3 you cannot duplex then, my customer needs to duplex.
      I have a feeling that this model cannot tolerate gloss. Thanks for the help.
      • GhostInTheMachine
        • Feb 2010
        • 88
        This is the recommended glossy as per the Product Support Guide.
        Kromekote
        Laser High Gloss Cover C1S
        Coated
        49.07lb. Bond 184gsm
        Kromekote
        Coated
        58.4lb. Bond 219gsm
        Notes:
        1. Poor feed or excessive curl may occur in high humidity environment.
        • msaeger
          • Sep 2008
          • 333
          What jam code are you getting ?
