MP5000 web end reset
  • CableGuy
    Impulse Drive Engineer
    • Oct 2008
    • 417
    Hi all
    I'm a tad confused here..... I replaced a web unit in a MP5000 earlier, as the web had completely run out. Usual practise here is to swap it out with a unit we rebuild in the shop. Everything went swimmingly, and the machine works fine. The only problem is I can't reset the little messege on the screen.....? I reset 7-806-008 as recommended in the manual and reset the usage count in 1-902-001 to 0..... But I can't get that messege to clear.... I think I recall a previous occasion where I struggled to clear that sucker. I think it's possible my brain is opperating in dim mode, must be the nice weather out there....
    Any Ideas?
  • Jomama46
    • 2900
    Reset 7806-008, press execute.
    sigpic
    A+; Network +; PDI+
    • barratec
      • Jun 2008
      • 162
      reset the SP 7804-005 too.
      • Rorschach
        • Nov 2008
        • 64
        What barratec said. Resetting the web PM counter via SP7804-005 usually does the trick for me.
        Today's subliminal quote is:
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          IIRC, there was a firmware update in regards to this matter as well. Might want to check your level and update accordingly.
