ricoh aficio sp c222sf light copies on copy - great printing
  • copierlady
    • 338
    any help?
  • teebee1234
    • Jul 2008
    • 1670
    Found this in the knowledge base....
    Copied images are faint (all colors). How can I fix this?
    Is the Toner Saver Mode is set to ON? (Default: OFF)
    Confirm the Toner Saver setting by printing the Configuration Page
    Follow these steps:
    1. Press any menu key.
    1. Press the [][] keys to select [Reports Print], and then press the [OK] key.
    1. Press the [][] keys to select [Configuration Page], and then press the [OK] key.
    The problem is resolved by setting the Toner Saver to [Off] again.
    Procedure: In Menu -> Machine settings -> Toner Saver Mode, change the setting from [On] to [Off].
    1. Press the [][] keys to select [Machine Settings], and then press the [OK] key.
    1. Press the [][] keys to select [Toner Saver Mode], and then press the [OK] key.
    1. Set the [Toner Saver Mode] to [Off].
    • copierlady
      • 338
      That was it. Thanks! Knowledge is power!
