Ricoh MP6000SP
  • Shark
    • 2
    Ricoh MP6000SP
  • Iommanxman
    • Aug 2009
    • 180
    I am having a similar problem on an MP5000. Wonder if they have a faulty batch of Dev?
    • mjmanu
      Background on copies
      hi
      please check the magnetic rollers, in many cases I found dirty mag rollers can make this problem. light copies with background.try this ,cheers
      • Iommanxman
        • Aug 2009
        • 180
        Originally posted by mjmanu
        hi
        This is true, however the machine's that we have in the field have been doing this since install.
        • tulipano
          • May 2010
          • 124
          • jwcheek
            Have you checked your drum ground. Have had several that was not making a good connection. Installed a old ft6655 dum ground and installed new devo, and have had good cq for the last 200k.
            • tcs04
              FORMER Techie
              • 1183
              Good call.... 75%+ that's the problem. If the resistance between the shaft and the "earth" contact is more that a few ohms it will screw up the process control.
