Ricoh Aficio 1022
  • gitana1983
    • Mar 2009
    • 141
    Ricoh Aficio 1022
    Hi everybody,
    I have a Ricoh Aficio 1022 (Lanier version Lanier 5622) with an Error code SC392. It has a brand new drum, and we have not being able to find out the problem The developer unit seems fine too.
    Any ideas on how to reset this error? SP5-810 and SP mode 7-807 didin't work.
    Any help is appreciated.
  • Martind12
    From the Manual,
    Someone forgot to remove the toner
    seal of the PCU
    ID sensor defective
    TD sensor abnormal
    Drum does not turn
    Development roller does not turn
    Poor connection of the PCU
    • TonerMunkeh
      Professional Moron
      • 3865
      The drum drive shaft has a little sprung gear on it, that might have siezed. Clean it off with IPA then put a touch of grease on it. If that fails it'll need a brand new PCU.
      Hit it.
      • Martind12
        Good call TM, forgot about that!!
        • gitana1983
          • Mar 2009
          • 141
          Thanks, I'll try that.!
          • Fearless V K
            • 620
            Also make sure the drive coupling piece for the development section of the drum unit is not missing. I rebuilt one of these drums and forgot to put it back on the end of the drum unit afterward and it popped a code when it was installed.
            Don't take that toner with me!
